Installation Service (per upgrade pack)
₺657,73 ₺552,71
Are you afraid to install the heater or lens by yourself without any assistance? No problem, our technicans are trained for this task. We can install your upgrade packs professionally so that you will receive a fully operational camera with desired modifications ready for integration into your network.
Varlık:stokta mevcut
Are you afraid to install the heater or lens by yourself without any assistance? No problem, our technicans are trained for this task. We can install your upgrade packs professionally so that you will receive a fully operational camera with desired modifications ready for integration into your network. We charge an installation fee of 14,99 Euro FOR EACH Upgrade Pack. Example: For the installation of a heater and a wide-angle lens in one camera you will need to order the installation service twice!
Kendi Yorumunuzu Yazın
Yorumunuz:Installation Service (per upgrade pack)
