16mm telephoto lens
for IN-9008 / IN-9408
₺1.315,90 ₺1.105,80
You want to focus more on details and less on a wide angle of view? Then you should use the 16mm lens. By simple changing the lens you will get an angle of view of about 25°.
Varlık:stokta mevcut
16mm lense
16mm lense for IN-9008 Full HD and IN-9408 2K+
You require more details in the image?
The IN-9008 Full HD and IN-9408 2K+ IP camera comes with a build in 4,3mm wide angle lens that offers a 90° viewing angle.
With the 16mm lens you will see an angle of 25°, so you actually see much less then with the original lens, but on the other hand you will see much more details inside the image.
Recommended distance: minimum of 15-30m to the target
Vergleich der Bildauschnitte
Direkter Bildvergleich
Vergrößern
4,3mm default lens
Vergrößern
8mm lens
Vergrößern
16mm tele-lens
Şartname
Genel Ürün Bilgileri
Odak uzaklığı 16 mm
Görüş açısı yaklaşık 25°
Lens Bağlantısı M12xP0.5
Gece görüşü 850nm ve 940nm kızılötesi ışık ile uyumlu
Objektif üzerinde sabit kızılötesi filtre? Hayır
Diğer Detaylar
İle uyumlu IN-9008 Full HD, IN-9008 Full HD PoE, IN-9408 2K+, IN-9408 2K+ PoE
Ağırlık 50g
Ölçüler cm cinsinden (Y / G / D) 0 / 0 / 0
Kendi Yorumunuzu Yazın
Yorumunuz:16mm telephoto lens
