3m connection cable (white)
for IN-9420 2K+ / IN-9820 4K
218,81 kr 183,87 kr
White 3 m INSTAR connection cable with power, LAN, reset, and alarm terminals. Original spare for IN-9420 2K+ & IN-9820 4K – ideal for indoor use.
Tillgänglighet:I lager
This white 3 m connection cable is an original INSTAR spare part for the IN-9420 2K+ and IN-9820 4K IP camera models.
It offers the following connections:
  • Power input
  • LAN port
  • Reset button
  • Alarm input & output
Perfect for replacing faulty cables or for clean indoor installations. The white color blends well with light-colored walls and ceilings for discreet setups.
Write Your Own Review
Du recenserar:3m connection cable (white)
