with invisible 940nm IR LEDs
7 545,44 ₽ 6 340,71 ₽
Infrared spotlight with 940nm invisible IR LEDs
Наличие:В наличии
Power
IN-906 Hi-Power Infrared Spotlight with 940nm invisible IR LEDs (black)
IN-906 Infrared Spotlight with 940nm
External infrared spotlight with 6 high powered IR LEDs for a realistic depth of approximatly 8-12 meters with 80 degree illumination angle. This infrared spotlight is the perfect companion for all cameras that can see 940nm light such as all INSTAR HD and FullHD cameras. You can also use the IN-906 Spotlight with every other night vision compatible cameras in order to improve the night view. The infrared spotlight can be directly plugged into every power socket and has an automatic sensor which automatically turns the spotlight on and off. As soon as it gets dark the IR LEDs will activate and illuminates the area with invisible infrared light. Please keep in mind that objects in front of the camera will reflect IR light thus increasing the illumination. The more surfaces in the near fascinate of the camera the more you will see.
Спецификация
Общая информация о продукте
Угол освещения 80°
Расстояние 8 - 12m
LEDs 6 Hi-Power LEDs
Длина волны 940nm
Мощность на светодиод ~ 1.5 W
Power supply 110-240 V / 50Hz
Другие детали
Совместим с IN-2901, IN-2904, IN-2905 V1, IN-2905 V2, IN-2905 PoE, IN-2907, IN-2908, IN-3001, IN-3003, IN-3005, IN-3010, IN-3010 PoE, IN-3011 PoE, IN-3011, IN-4009, IN-4010, IN-4010 V2, IN-4011, IN-5905HD, IN-5907HD, IN-5907HD PoE, IN-6001HD, IN-6011HD, IN-6012HD, IN-6012HD PoE, IN-6014HD, IN-6014HD PoE, IN-7011HD, IN-7011HD PoE, IN-8003 Full HD PoE, IN-8015 Full HD, IN-8015 Full HD PoE, IN-9008 Full HD, IN-9008 Full HD PoE, IN-9010 Full HD, IN-9020 Full HD, IN-8401 2K+, IN-8403 2K+ PoE, IN-8415 2K+, IN-9408 2K+, IN-9408 2K+ PoE, IN-9420 2K+, IN-8815 4K, IN-9808 4K, IN-9820 4K
Вес 640g
Измерения в см (В / Ш / Г) 11.4 / 8.5 / 8.5
Напишите свой собственный отзыв
You're reviewing:IN-906 Hi-Power Infrared Spotlight (black)
