IN-Motion 300 white
€49.99 €42.01
N-MOTION is a passive (PIR) motion detector. This sensor is the perfect extension for your ip camera in order to minimize false alarms.
在庫あり:在庫あり
color:white
IN-Motion 300 black IN-Motion 300 white
What is IN-MOTION 300?
What is PIR?
Advantages:
Significant reduction of false alarms of your IP camera
Very easy Plug n Play Technology. Simply plug it in the power outlet and connect it to your ip camera
Accurate detection of humans thanks to high quality infrared sensors
Contents of delivery:
1x IN-MOTION 300
1x 4m signal cable
1x power supply (12V / 3A) with 3m cable
1x set of dowls and screws
1x installation manual
Attention
