What is PIR?
Advantages:
Significant reduction of false alarms of your IP cameraVery easy Plug n Play Technology. Simply plug it in the power outlet and connect it to your ip cameraAccurate detection of humans thanks to high quality infrared sensors
Contents of delivery:
1x IN-MOTION 3001x 4m signal cable1x power supply (12V / 3A) with 3m cable1x set of dowls and screws1x installation manual
Attention
To make our website even better, we use functional and analytical cookies. Information from this website and your preferences are stored in these cookies by your browser.
Essential
Essential cookies are strictly necessary to guarantee the proper functioning of the website.
Analytical
With this you allow us to collect anonymous data about the use of the website with third party cookies, such as the number of clicks and the behavior of visitors on the website. In addition, we can also perform marketing-related actions via this option.
By activating this cookie, you help us to further improve your experience.
With this you allow us to collect marketing-related data via third party cookies.
プライバシーポリシー
Read more about the use of cookies on this website in our privacy policy.privacy policy
We use functional and analytical cookies to make our website better.Would you like to know more about our cookies? Click on Cookie settings.
