IN-PoE1000 PoE Injector black
49,99 € 42,01 €
The INSTAR IN-PoE 1000 PoE Injector is a reliable and efficient device designed to simplify the power supply of your network devices. With the ability to combine both the network signal and power into a single Ethernet cable, it eliminates the need for additional power cables, making installations cleaner and more organized. The IN-PoE 1000 supports the IEEE 802.3af/at standard, ensuring compatibility with a wide range of PoE-enabled devices such as IP cameras, wireless access points, and VoIP phones. It offers a high data transfer rate of up to 1000Mbps, ensuring fast and stable network connectivity. With its compact design and easy installation, the INSTAR IN-PoE 1000 PoE Injector is an ideal solution for powering and connecting your PoE devices in a convenient and efficient manner.
Disponibilité:En rupture de stock
IN-PoE1000
What is a PoE Injector?
In order to operate your INSTAR Camera with less cables as possible the IN-PoE1000 will combine the network signal and the power into one "single" network cable. Your network devices (such as your cameras) need to support PoE (Power over Ethernet). The network signal can be transmitted with up to 1000MBits while the injector operates with 48V and 35 Watt tops. With the IN-PoE1000 you are always on the save side. The PoE Injector meets the IEEE 802.3at standard and automatically detects if your end device supports PoE and turns it off in case your device is not supported. This way your devices will not be damaged.
Advantages
Super fast data transfer thanks to 1000MBit TCan handle devices with up to 35 Watt. Most injectors only support 15,6 Watt Thanks to a handy sliding system you can combine several injectors in order to save space Quick and easy installation
Content of delivery
1x IN-PoE1000 (PoE Injector) in black 1x power cable 1x installation guide
spécification
Informations générales sur le produit
Tension d'entrée 100 - 240V
Puissance de sortie IEEE 802.3at (max. 48V, 35W)
Chipset -
Taux de transfert de données 1000 MBit
Fonctionnalité spéciale Combine une connexion de données et d'alimentation
Autres détails
Compatible avec le modèle de caméra Toutes les caméras PoE
Poids 200g
Mesures en cm (H / L / P) 8.8 / 5.1 / 16.6
Vous commentez :IN-PoE1000 PoE Injector black
