40cm short connection cable
for IN-9420 2K+ / IN-9820 4K
€12.99 €10.92
Optional short connection cable for INSTAR IP cameras IN-9420 2K+ and IN-9820 4K – perfect for space-saving installation inside the camera's wall mount. Includes only essential ports: network, power, and reset.
Availability:In stock
This short connection cable is the ideal accessory for the INSTAR surveillance cameras IN-9420 2K+ and IN-9820 4K. Designed as a compact and tidy alternative to the included 3 m standard cable, it allows for a concealed installation directly inside the camera’s wall mount.
Unlike the standard cable, which offers power, network, reset, and alarm I/O connectors, this compact version is streamlined to include only the most essential connections: network, power, and reset button. This makes the cable particularly space-efficient – perfect for discreet wall or ceiling installations.
Optimized for clean cable management and minimalist installations, this optional short cable is tailored for users who value a sleek setup without compromising on core functionality. Fully compatible with the INSTAR IP camera models IN-9420 2K+ and IN-9820 4K.
Write Your Own Review
You're reviewing:40cm short connection cable
Your Rating
