€169.99 €142.85
Availability:Out of stock
Easy Plug & Play Setup
Put an end to power cables
Power Supply & Port Priority
Cable- & Connection Diagnosis
specification
Network Features
Uplink Auto MDI / MDI-X
Ports 2 uplink ports, 8 ports (PoE support)
PoE Output max. 25.5 watts (802.3af), max. 30 watts (802.3at)
Total PoE Output 250 watts
Swtiching Capacity 16Gbps
Buffer Memory 192Kb
Power Supply & Size
Max. operating temperature -5°C to 55°C
Measurements in cm (H / W / D) 2.9 / 19 / 10.5
Write Your Own Review
You're reviewing:IN-PoE 8200 - Gigabit PoE Switch
Your Rating
