with slightly visible 850nm LEDs
€99.99 €84.03
Spotlight with 15 Hi-Power IR LEDs
Availability:In stock
Heater
IN-907 Infrared Spotlight
specification
General Product Information
Illumination angle 60°
Distance 30 - 35m
LEDs 15 Hi-Power LEDs
Wavelength 850nm
Power per LED ~ 1 W
Power supply 110-240 V / 50Hz
Other Details
Compatible with IN-2901, IN-2904, IN-2905 V1, IN-2905 V2, IN-2905 PoE, IN-2907, IN-2908, IN-3001, IN-3003, IN-3005, IN-3010, IN-3010 PoE, IN-3011 PoE, IN-3011, IN-4009, IN-4010, IN-4010 V2, IN-4011, IN-5905HD, IN-5907HD, IN-5907HD PoE, IN-6001HD, IN-6011HD, IN-6012HD, IN-6012HD PoE, IN-6014HD, IN-6014HD PoE, IN-7011HD, IN-7011HD PoE, IN-8003 Full HD PoE, IN-8015 Full HD, IN-8015 Full HD PoE, IN-9008 Full HD, IN-9008 Full HD PoE, IN-9010 Full HD, IN-9020 Full HD, IN-8401 2K+, IN-8403 2K+ PoE, IN-8415 2K+, IN-9408 2K+, IN-9408 2K+ PoE, IN-9420 2K+, IN-8815 4K, IN-9808 4K, IN-9820 4K
Weight 1340g
Measurements in cm (H / W / D) 18 / 13.9 / 9.5
Write Your Own Review
You're reviewing:IN-907 Hi-Power Infrared Spotlight (black)
Your Rating
