Compare all IP indoor cameras
Indoor Camera Comparison
  IN-8401 2K+ IN-8403 2K+ PoE IN-8415 2K+ IN-8815 4K
Surveillance camera IN-8401 2K+ Security camera IN-8403 2K+ PoE Network camera IN-8415 2K+ Network camera IN-8815 4K
Optics & Picture
CMOS Sensor 1/2.8 inch
Sony starlight sensor
1/2.8 inch
1/2.8 inch
1/2.8 inch
MegaPixel 4 MP 4 MP 4 MP 8 MP
Illumination STARVIS* STARVIS* STARVIS* STARVIS*
Lens Mount S-Mount
M12 x P0.5
S-Mount
M12 x P0.5
S-Mount
M12 x P0.5
S-Mount
M12 x P0.5
Standard Lens 4,3mm 4,3mm 4,3mm 4,3mm
Viewing Angle about 90° about 90° about 90° about 100°
Video Compression H265
H264
MJPEG
H265
H264
MJPEG
H265
H264
MJPEG
H265
H264
MJPEG
min. Resolution 1280x720 1280x720 1280x720 1280x720
max. Resolution 2560x1440 2560x1440 2560x1440 3840x2160
Framerate 30fps (2K+) 30fps (2K+) 30fps (2K+) 30fps (4K)
Picture (turn / mirror) 180° / yes 180° / yes 180° / yes 180° / yes
Connection
10/100 MBit LAN is supported is supported is supported is supported
Power over Ethernet (PoE) is not supported is supported
IEEE 802.3af
is supported
IEEE 802.3af
is supported
IEEE 802.3af
Wireless LAN (WiFi) is supported
433 Mbit WiFi (802.11ac)
is supported
866 Mbit WiFi (802.11ac)
Wifi Frequenz 2.4Ghz
5Ghz
is not supported 2.4Ghz
5Ghz
2.4Ghz
5Ghz
max. recommended Wifi Distance ca. 8-12m is not supported ca. 8-12m ca. 10-15m
detachable Antenna is not supported is not supported is supported
1x 3.5db antenna
is supported
2x 3.5db antenna
WiFi Encryption WPA2 / WPA3 / Enterprise is not supported WPA2 / WPA3 / Enterprise WPA2 / WPA3 / Enterprise
Night Vision
Amount of Infrared LEDs 6 IR-LEDs (940nm)
4 IR-LEDs (850nm)
2 IR-LEDs (850nm)
2 White-Light LEDs
10 IR-LEDs (850nm) 10 IR-LEDs (850nm)
Type of Infrared LEDs 940nm / 850nm 850nm 850nm 850nm
max. Range 5-10m 8-20m 8-12m 8-12m
Night vision controlable by PIR is supported is supported is supported is supported
integrated IR Cut Filter is supported is supported is supported is supported
Features
Motion Detection (by Image comparison) is supported is supported is supported is supported
Built-in PIR Motion Detector is supported is supported is supported is supported
AI Object detection is supported is supported is supported is supported
Alarm I/O (In / Out) is not supported is supportedis supported is supportedis supported is supportedis supported
Alarm via Email is supported is supported is supported is supported
Storage inside the INSTAR Cloud (optional) is supported is supported is supported is supported
FTPS Encryption is supported is supported is supported is supported
SFTP Upload is supported is supported is supported is supported
Alarm via FTP Upload is supported is supported is supported is supported
FTP upload by fixed intervals is supported is supported is supported is supported
Scheduler for Alarm is supported is supported is supported is supported
Video Recording is supported is supported is supported is supported
Pre-recording before the alarm is supported
0 - 10 seconds
is supported
0 - 10 seconds
is supported
0 - 10 seconds
is supported
0 - 10 seconds
integrated SD Card 32GB MicroSD
(max. up to 1024GB / 1 TB)
Snapshots is supported is supported is supported is supported
Photo Series to SD / FTP / Email is supportedis supportedis supported is supportedis supportedis supported is supportedis supportedis supported is supportedis supportedis supported
HTTPS Encryption is supported is supported is supported is supported
Privacy mask is supported
max. 8 areas
is supported
max. 8 areas
is supported
max. 8 areas
is supported
max. 8 areas
Multi-View of multiple cameras is supported* is supported* is supported* is supported*
integrated DDNS Address is supported is supported is supported is supported
Third Party DDNS possible is supported is supported is supported is supported
integrated P2P UID is supported is supported is supported is supported
integrated Microphone is supported is supported is supported is supported
Noise Reduction is supported is supported is supported is supported
Echo Cancelation is supported is supported is supported is supported
integrated Speaker is supported is not supported is supported is supported
Audio Output is not supported is not supported is supported is supported
Pan & Tilt Control is not supported is not supported 350° / 75° 350° / 75°
max. storable Positions is not supported is not supported 8 8
Smart Home integration
Amazon Alexa is supported is supported is supported is supported
Google (Home) Nest is supported is supported is supported is supported
IFTTT is supported is supported is supported is supported
ONVIF support Yes (Profile S) Yes (Profile S) Yes (Profile S) Yes (Profile S)
MQTT Smarthome protocol is supported
MQTT v5
is supported
MQTT v5
is supported
MQTT v5
is supported
MQTT v5
MQTT over Websocket is supported is supported is supported is supported
Alarmserver (HTTP(S) requests) is supported is supported is supported is supported
CGI Interface is supported is supported is supported is supported
User Access Right Management is supported is supported is supported is supported
Password Protection is supported is supported is supported is supported
Time Synchronization is supported
NTP / secure NTP (NTPS)
is supported
is supported
is supported
supported Operating Systems
(Windows / Mac / Linux)
supported Mobile Devices
(iPhone / iPad / Android / Blackberry / WinPhone)
is supportedis supportedis supportedis supportedis supported is supportedis supportedis supportedis supportedis supported is supportedis supportedis supportedis supportedis supported is supportedis supportedis supportedis supportedis supported
Details
Types of mounting stand / wall and
ceiling mounting
stand / wall and
ceiling mounting
stand / wall and
ceiling mounting
stand / wall and
ceiling mounting
max. working temperature -5°C to
55°C
-5°C to
55°C
-5°C to
55°C
-5°C to
55°C
Power socket 100 - 240V 100 - 240V 100 - 240V 100 - 240V
Length of power supply 3m 1.5m 3m 3m
Power supply 5V / 1.5A PoE or PoE or PoE or
12V / 1.5A 5V / 2A 5V / 2A
max. Power consumption 5.0 Watt 8.0 Watt 8.0 Watt 9.5 Watt
Weight 185g 550g 355g 355g
Measurements in cm (H/W/D) 15 / 6.5 / 6.5 10 / 11.8 / 11.8 12.4 / 11 / 11 12.4 / 11 / 11
* With our free App InstarVision for your Smartphone (Android, iOS, WinPhone, Blackberry, Amazon Kindle) and Windows 10/11
* STARVIS is a trademark of Sony Corporation. A STARVIS sensor is defined by a sensitivity of 2000 mV or more per 1 μm² when illuminated with a 706 cd/m² light source, F5.6 in 1s accumulation equivalent.
