IN-9420 2K+ white
LAN / PoE / WiFi Version
Wide Angle
Approx. 30-120º Viewing Angle
6 IR and White Light LEDs
350° Pan 100° Tilt
AI-based Object Detection
Heat-sensitive Motion Sensor
Weather Protection
IP66 Weatherproof
PUSH Notification
to Your Phone
Integrate the IP Camera
Directly into the Home App
Native Smart Home
Support with MQTT
Mobile Apps
Free Apps for
Your Smartphone
Encrypted DDNS Access,
E-Mail & FTP Transfer
and Guest Accounts
Software-based Detection
Audio Surveillance
Integrated Noise Detection
Video Recordings
Storage of Alarm Videos
on Internal SD Card
Alarm Schedule
Alarm Activation According
to Schedule
Alarm I/O
For External Sensors &
Alarm Systems
Alarm Signal
Alarm Siren When an
Alarm is Triggered
DS-Lite Internet Connections
Microphone Included
Speaker
Integrated Speaker
Black Out Areas You
Must Not Record
Up to 4 Customizable
Motion Detection Areas
FTP Upload to External
Storage (NAS / Router)
E-Mail Alarm Notification
Alarm Lead Time
Alarm Recordings
With 3-10s Lead Time
Web User Interface for
Support for SDHC
Up to 256GB
Store Your Alarm Videos
In Our Cloud Platform
2K+ Video Resolution
The new Sony STARVIS CMOS sensor provides double the resolution of the sensor in a 1080p (FullHD) camera model. Thanks to the additional 2 million pixels, you can also see distant objects in all detail.
Comforting Sense of Security
Avoid false alarms by linking software-based motion detection with the integrated body heat sensor (Passive Infrared, PIR). This way, you only receive alerts when something has actually happened.
350° Pan & 100° Tilt
Two-Way Talk
Speaker
Built-in Speaker
Alarm Notification
PTZ & Preset Positions
Keep Your
Alarm Videos Safe
Your camera can store alarm recordings on the internal SD card, upload them to a private FTP(S) or SFTP server, or transfer them to the optional INSTAR Cloud to keep the files secure. Each alarm event can trigger a short alarm recording that will be automatically uploaded to your INSTAR Cloud account – safe, on German servers, and accessible only to you!
More info about the CloudSD Card
max. up to 256 GB
e.g. Your NAS / Router
Automatic upload to the Cloud (optional)
A camera that speaks "Smart Home"
Smart home systems are very diverse. But what they have in common is the language they speak. Wireless sensors connect to your smart home gateway via standards like Zigbee, Z-Wave, or EnOcean. While wired devices mostly communicate via the MQTT protocol. Use your camera as an MQTT hub in your home network and give your smart home 100% control over all camera functions. By providing this standard conformity, you can indirectly link any sensor in your house to your camera.
Easy Installation
Scope of Delivery
Manual
Wall Mount
Ceiling Mount
Screws & Anchors
Power Adapter
Product FAQ
- What are the installation requirements? aa
Everything you need to install the camera and add it to your local network is included in the package. Simply connect the camera to your router via LAN cable or Wi-Fi. Once the connection is established, you can use your smartphone or computer to configure your camera according to your needs. All INSTAR cameras can be used within your network without an internet connection. Only if you access the camera from outside your network, you will need a router with internet connection - no additional mandatory fees or subscriptions are required for using INSTAR cameras.
- Do I need a plugin (e.g., Flash) to view the camera's video stream? aa
No, all INSTAR 2K+ models offer the option to view the live video as an HTML5 video stream. You do not need any additional browser plugin to view the video. The HTML5 video can also be transmitted encrypted via HTTPS including audio. Alternatively, the video can also be captured via MJPEG or JPEG stream.
- Are there any additional costs after purchasing the camera? aa
INSTAR cameras do not have a mandatory subscription service that would incur additional costs. However, INSTAR offers optional PC software (InstarVision 2 for Windows and MacOS) and cloud storage plans (INSTAR Cloud) for expansion needs.
- What size and weight is this camera? aa
