Heater for IN-9X08
IN-9008 / IN-9408 2K+ / IN-9808 4K
١٠٦٫٩٩ ر.س.‏ ٨٩٫٩١ ر.س.‏
Energy-efficient heater for INSTAR IP cameras IN-9808 4K, IN-9408 2K+ and IN-9008 Full HD. Perfect for cold outdoor conditions. Works even with PoE and mounts easily inside the camera housing.
التوفر:متوفر
Heater
Heater for IN-9008 Full HD, IN-9408 2K+ and IN-9808 4K
This optional internal heater ensures that your INSTAR surveillance camera remains fully operational even in freezing temperatures. It is compatible with the IN-9808 4K, IN-9408 2K+, and IN-9008 Full HD camera models and is designed specifically for outdoor winter operation.
Thanks to its low power consumption, the heater can be used with both standard power supplies and Power-over-Ethernet (PoE) setups. It places minimal load on your PoE system, making it suitable for energy-efficient installations.
Installation is straightforward – the heater is mounted directly inside the camera housing, with no external components needed. A step-by-step installation guide is included, making it easy for both DIY users and professionals.
With this heater, your IP camera is winter-ready – ensuring reliable surveillance even in snow and freezing temperatures.
تخصيص
معلومات عامة عن المنتج
modified working temperature -20°C to 55°C
Power supply 12V (through cameras power supply or PoE)
تفاصيل أخرى
متوافق مع IN-9008 Full HD, IN-9008 Full HD PoE, IN-9408 2K+, IN-9408 2K+ PoE, IN-9808 4K
الوزن 100 g
القياسات بالسنتيمتر (ارتفاع / عرض / عمق) 0 / 0 / 0
كتابة مراجعتك
انت تقيم:Heater for IN-9X08
