IN-Motion 300 black
٢١٤٫٠٢ ر.س.‏ ١٧٩٫٨٥ ر.س.‏
N-MOTION is a passive (PIR) motion detector. This sensor is the perfect extension for your ip camera in order to minimize false alarms.
التوفر:متوفر
color:black
IN-Motion 300 black IN-Motion 300 white
What is IN-MOTION 300?
What is PIR?
Advantages:
Significant reduction of false alarms of your IP camera Very easy Plug n Play Technology. Simply plug it in the power outlet and connect it to your ip camera Accurate detection of humans thanks to high quality infrared sensors
Contents of delivery:
1x IN-MOTION 300 1x 4m signal cable 1x power supply (12V / 3A) with 3m cable 1x set of dowls and screws 1x installation manual
Attention
كتابة مراجعتك
انت تقيم:IN-Motion 300 black
